8 years ago[SignalTap] How to change Trigger Conditions on the fly?
Hi All, Let's say I defined several signals https://alteraforum.com/forum/attachment.php?attachmentid=14705&stc=1 to be the triggers in the SignalTap (triggered ever on the rising or falling ed...
8 years agothe trigger configuration is possible in real time during debug. You just have to stop data acquisition, configure you trigger conditions the way you want and then run again (the acquisition not quartus compilation). But if you want to change the way this triggers are evaluated ( from "and" to "or " let's say) you'll have to rerun the compilation.(because some rtl logic will change in SigTap autofab or whatever...)
Unchecking "trigger enable" will disable the trigger ? from the name , that would be the logic behaviour. I have never tried that to be honest. But I'm sure that changing the condition for that "signal" to "don't care" would do the job.
