15 years agoah, good point.
i think SSRAM should be fairly straight forward. you'll want to find the datasheet for the RAM, and maybe use another kit's constraints as an example (along with the TimeQuest documentation). here's the constraint from the CIII NEEK kit:##SSRAM Constraints
set_output_delay -clock -reference_pin 2.4
set_input_delay -clock -reference_pin 4.1
set_multicycle_path -from -setup -end 2
