15 years ago --- Quote Start --- The classical timing analyzer can't see all possible timing violations, particularly with multiple timing domains. --- Quote End --- Thank you for your help Frank. You were right, Timequest solved some of my problems. But I am new to timequest, so I don't really know how I can define all the constraints. I constrained only the main clock and PLL clocks for now. I guess the remaining problems are caused by undefined constraints. I use DE2-70 board and I am not sure about what the timing values should be set. Is there any predetermined constraint values I can use or how can I determine them?
