15 years agoHi pletz,
I've edit my post. Actually I mean the reverse. Design works normally with Signaltap enabled. When I disable it, the problems occur. I use classic timing analyzer and there are no timing violations reported. I use 2 clocks in the design (50M and 200MHz). Is there anything I should consider in multiclock case? If you need to know any other information please ask me. Thanks for your help.
