15 years ago --- Quote Start --- I am working on a design in Verilog. The design works normally without signaltap enabled. But, when I enable signaltap, the operation of the circuit changes. The results become erroneous. I think signaltap is an observer only, so it shouldn't change the design operation. Am I doing sth wrong? Does anyone have an idea about this problem? --- Quote End --- Hi, yes Signaltap is an "observer", but it has an influence to the synthesis, routing and placement. Did you get new timing violation when you use signaltap ? Kind regards GPK
