18 years agoThanks. I'll install the latest SP shortly.
Regarding trigger-in/trigger-out. I'm chaining two Singal Tap instances. And it simply doesn't work at all. The master instance (the one using trigger out) triggers, but the "slave" instance (the one using trigger in) never triggers. Just in case I tried all possible trigger level combinations. I also tried using additional trigger conditions, and also with trigger-in alone. No matter what I do, the "slave" instance never triggers (unless I disable trigger-in, in which case it works without problems).
