18 years agoThanks. Yes, they seem to be harmless. Are you sure this is fixed in 7.2 SP1? I can't find any mention about the issue on the release notes.
Btw, even power-up triggers seem to work fine (but I didn't test them too much). The only feature that doesn't work for me is chaining two instances using trigger-in/trigger-out link (no idea if this is related to the warnings, probably not).
