15 years agoThere is a simple code
tp1 <= tp1_as; process (fpga_reset_h, sys_clk_int) is begin if(fpga_reset_h = '1') then --tp1 <= '0'; tp2 <= '0'; tp3 <= '0'; ser_txd <= '1'; elsif(rising_edge(sys_clk_int)) then tp2 <= tp2_as; tp3 <= tp3_as; ser_txd <= ser_rxd;-- Synchronous Sequential Statement(s) end if; end process; a1 : ENTITY work.spll PORT MAP ( areset => fpga_reset_h, inclk0 => sys_clk, c0 => sys_clk_int, c1 => tp1_as, c2 => tp2_as, locked => tp3_as ); There are no timing violations. SCD file contain correct clock constrains. SignalTap connected to sys_clk_int and tp1, tp2, tp3. SignalTap start off-loading data at some moment, but I don't see any graphical data. Pressing "Read Data" button gives result that looks like valid data at incorrect trigger condition Thanks
