13 years agoSignalTap advanced triggering?
Anyone got an example of how to setup advanced or sequential trigger-flow in SignalTap?
I want to trigger a capture on the first '0' after say, 5 succesive '1's on my input, using a 10 x faster-than-my-data capture-clock. Or can I specify a serial pattern ("111110xxxx" and then trigger) to achieve the same? Mostly curious about what you can do - rather than desparate for a solution. Thanks.
