8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All,
Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will this logic be not implemented (removed from SignalTap)? Thank you!2 Replies
1.There is no option to merge SignalTap file together. 2.By disabling an instance in the SignalTap file before the compilation, will not implemented any logic related to signalTab. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
As far as I see, disabling instances in the Hierarchy Display does not change the compilation result and can be done instantly without need for recompilation.
