8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will ...
8 years agoAs far as I see, disabling instances in the Hierarchy Display does not change the compilation result and can be done instantly without need for recompilation.
