Yes, I am. I took a screenshot and highlighted two signals. One of them comes from the test bench as I mentioned before. So you can see, if I don't force the signal "/mixuart2_vhd_tst/i1/tx_busy_s" to be '0', it doesn't work.
And also, why does tx_busy_s stay '0'? I'm expecting it to be '1' when "Start" goes '1'.
Here is a picture of the simulation:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8213 Main Code:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.NUMERIC_STD.all;
Entity mixuart2 is
PORT (
Clock_50: in std_logic;
Sw: in std_logic_vector(7 downto 0);
Key: in std_logic;
Reset: in std_logic;
ledg: out std_logic_vector(7 downto 0);
uart_txd: out std_logic
End mixuart2;
Architecture mixuart_a of mixuart2 is
signal tx_data_s: std_logic_vector(7 downto 0);
signal tx_start_s: std_logic:='0';
signal tx_busy_s: std_logic:='0';
Component Tx
PORT(
Clk: in std_logic;
Start: in std_logic;
Busy: out std_logic;
Data: in std_logic_vector(7 downto 0);
Tx_line: out std_logic;
Stop: in std_logic
End Component Tx;
BEGIN
C1: Tx PORT MAP (Clock_50, Tx_start_s, Tx_busy_s, Tx_data_s, uart_txd,Reset);
PROCESS(Clock_50,Reset)
BEGIN
IF (Clock_50'event and Clock_50='1') then
IF (Reset='1') then
Tx_start_s<='0';
ELSIF(Key='1' and Tx_busy_s='0') then
Tx_data_s<=Sw;
Tx_start_s<='1';
Ledg<=Tx_data_s;
ELSE
Tx_start_s<='0';
END IF;
END IF;
END PROCESS;
END mixuart_a;
Tx:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
Entity Tx is
PORT(
Clk: in std_logic;
busy: out std_logic;
data: in std_logic_vector(7 downto 0);
tx_line: out std_logic;
Stop: in std_logic
End Tx;
Architecture tx_a of tx is
signal clk_div_s: integer range 0 to 5208:=0;
signal index_s: integer range 0 to 9:=0;
signal datafll_s: std_logic_vector(9 downto 0);
signal tx_flag_s: std_logic:='0';
BEGIN
PROCESS(Clk,Stop)
BEGIN
IF(Clk'event and clk='1') THEN
IF (Stop='1') THEN
tx_flag_s<='0';
busy<='0';
datafll_s(8 downto 1)<="00000000";
index_s<=0;
clk_div_s<=0;
ELSIF(tx_flag_s='0' and Start='1') THEN
tx_flag_s<='1';
busy<='1';
datafll_s(0)<='0';
datafll_s(9)<='1';
datafll_s(8 downto 1)<=data;
END IF;
IF(tx_flag_s='1') THEN
IF(clk_div_s<5207) THEN
clk_div_s<=clk_div_s+1;
ELSE
clk_div_s<=0;
END IF;
IF(clk_div_s=2600)THEN
Tx_line<=datafll_s(index_s);
IF(index_s<9) THEN
index_s<=index_s+1;
ELSE
tx_flag_s<='0';
busy<='0';
index_s<=0;
END IF;
END IF;
END IF;
END IF;
END PROCESS;
END tx_a;
Test bench:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY mixuart2_vhd_tst IS
END mixuart2_vhd_tst;
ARCHITECTURE mixuart2_arch OF mixuart2_vhd_tst IS
-- constants
-- signals
SIGNAL Clock_50 : STD_LOGIC;
SIGNAL Key : STD_LOGIC;
SIGNAL ledg : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL Reset : STD_LOGIC;
SIGNAL Sw : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL uart_txd : STD_LOGIC;
signal tx_busy_s : Std_LOGIC;
constant clk_period: time:=20ns;
COMPONENT mixuart2
PORT (
Clock_50 : IN STD_LOGIC;
Key : IN STD_LOGIC;
ledg : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
Reset : IN STD_LOGIC;
Sw : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
uart_txd : OUT STD_LOGIC
END COMPONENT;
BEGIN
i1 : mixuart2
PORT MAP (
-- list connections between master ports and signals
Clock_50 => Clock_50,
Key => Key,
ledg => ledg,
Reset => Reset,
Sw => Sw,
uart_txd => uart_txd
init : PROCESS
-- variable declarations
BEGIN
Clock_50<='0';
wait for clk_period/2;
Clock_50<='1';
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
tx_busy_s<='0';
Reset<='0';
Key<='0';
Sw<="00110011";
wait for 50 ns;
key<='1';
wait for 10 us;
WAIT;
END PROCESS always;
END mixuart2_arch;
Thank you.
