AEsqu
Contributor
4 years agosignal tap: pre-sythesis shall be named post-synthesis
It is possible to probe signal tap using
pre-synthesis or post-fitting results from quartus.
This is actually not correct,
if you run compile only, you cannot probe the "pre-synthesis...
AEsqu
Contributor
4 years agoNo. run Analysis & Elaboration and you will see that you cannot probe the signal tap probes (delete the db before and try with a vqm from synplify). Quartus std edition.
sstrell
4 years agoI wasn’t talking about a .vqm, which obviously has been synthesized by another tool. I’m talking about straight HDL code added to a Quartus project.
- AEsqu4 years ago
Contributor
I use a mix of straight verilog/vhdl and one vqm.
The vqm after elaboration shall be normally enough and not require a synthesis either.
Please double check.
- sstrell4 years ago
I’m not sure what you’re saying here but a .vqm by its definition is HDL already synthesized in another tool, so by its nature, it’s already post-synthesis. In Quartus to integrate it in a project, yes, you do have to perform synthesis.- AEsqu4 years ago
Contributor
So by selecting "signal tap: pre-sythesis", I still need to run a synthesis,
as originally posted, correct?
Which is strange to me, as Quartus properly compile and elaborate the RTL + the VQM without problem,
so it shouldn't required a synthesis.
As you stated, VQM is already synthesized, so why having to run the synthesis step again in quartus to include it in the elaborated database?
