AEsqu
Contributor
4 years agosignal tap: pre-sythesis shall be named post-synthesis
It is possible to probe signal tap using
pre-synthesis or post-fitting results from quartus.
This is actually not correct,
if you run compile only, you cannot probe the "pre-synthesis...
sstrell
4 years agoNo. Pre-synthesis refers to signals exactly as they are defined in your HDL code. You don't need to perform full synthesis to get pre-synthesis signals for Signal Tap. Just run Analysis & Elaboration, which does not perform any synthesis. The compiler checks your HDL files and makes the pre-synthesis signals available for assignments like in the Assignment Editor and for tapping in Signal Tap.
- AEsqu4 years ago
Contributor
No. run Analysis & Elaboration and you will see that you cannot probe the signal tap probes (delete the db before and try with a vqm from synplify). Quartus std edition.
- sstrell4 years ago
I wasn’t talking about a .vqm, which obviously has been synthesized by another tool. I’m talking about straight HDL code added to a Quartus project.- AEsqu4 years ago
Contributor
I use a mix of straight verilog/vhdl and one vqm.
The vqm after elaboration shall be normally enough and not require a synthesis either.
Please double check.
