ASvir2
7 years agoSignal tap not working in Quartus Pro 18.0
Hi all!
I'm working on a design for a custom board with Cyclone 10 GX FPGA.
I am able to program the design using jtag, but I'm unable to use Signal Tap (there's "instance not found" message under status).
I downloaded .sof for sure because I see leds toggling, in fitter report signal tap uses some resources and it's enabled in project settings.
Did anyone else have this issue?
I'm using Quartus Pro 18.0.
Thank you.
1 Reply
- ASvir2
Just a quick update, I managed to solve my problem by changing the jtag clock frequency on usb blaster II from 24 MHz to 6MHz.
