Signal Tap Logic Analyzer II Trigger Condition
CLOCK_50 should not be in the node list. You already have that as the capture clock. I think perhaps you mean to put the 1Hz clock as the capture clock and have CLOCK_50 in the node list, but then the capture clock would be way too slow to capture CLOCK_50. So simply have the 1Hz clock as the capture clock and remove CLOCK_50 from the node list. With CLOCK_50 as the sampling clock, you're filling up the buffer long before there's even one cycle of the counter.
You also don't need the trigger in. Disable that.
- Hamza_523 years ago
Yes regarding the clock you are right. I was also thinking the same that may be my buffer is getting overwrite with 50 Mhz clock thats why i am only able to see one sample.
But disabling the trigger in so how the data acquisition will stop as i dont want any extra samples
As the reason i am testing trigger in because i want to run a C program on one of my design which have to stop after a particular condition is match or if all the lines of the code is executed. I dont want to stop sampling before that and i also dont want samples after that
