14 years agoSignal tap giving bizarre values
Hello i've used a lot of signal tap in my developer life however i am working in a project right now and it's behaving really weird.
I am using Quartus V11.0sp1, i've set some constant values at the input of a module and they are changing... how is that possible? A lot of registers that i am not changing the value in my code are swapping the value (says signaltap) My acquisition clock is 100mhz and so is my system clock, i am running continuous capture of signal tap... Is there any known issue with V11.0sp1 and signal tap?
