Signal Tap example from Intel training course always fails timing
Hi @hcom ,
Any further update?
--- Quote Start ---
proc set_s10_false_path_constraint { } { if {$::TimeQuestInfo(family) == "Cyclone 10 GX"}
{ set_false_path -from "the node"
set_false_path -from "the node" } }
--- Quote End ---
Does the alternative provided above help?
Sheng
@ShengN_Intel I must admit, I am shocked by your suggestion. Of course, I could set timing ignores everywhere in my design and then I would never see any timing errors. But then I also wouldn't be constraining anything, so (without specific justification) this would be an incredibly bad thing to do.
- ShengN_altera4 years ago
Hi @hcom ,
Due to this thread is opened for too long time and no response from you for quite some time, so I had closed pending this thread.
You may open a new thread on this topic and I will pick up the new one when it comes in.
I will reflect this to internal engineering and come back to you in new thread if there is any feedback from them.
Sheng
