hcom
4 years agoSignal Tap example from Intel training course always fails timing
I am using Quartus Prime 21.1.0 Build 169 03/24/2021 SC Pro Edition to target a Cyclone 10 GX (10CX085) FPGA.
I followed this Intel training course to set up Signal Tap:
https://learning.intel.co...
hcom
4 years ago@ShengN_Intel No, there is no solution yet. It still fails timing.
I still need a solution, but nothing I have tried has worked.
ShengN_altera
4 years agoHi @hcom ,
I think you can straight set false path from those two fail timing nodes. Try to modify a bit the original Quartus SDC template like below.
proc set_s10_false_path_constraint { } { if {$::TimeQuestInfo(family) == "Cyclone 10 GX"}
{ set_false_path -from "the node"
set_false_path -from "the node" } }
Sheng
