Signal Tap example from Intel training course always fails timing
@ShengN_Intel That is almost exactly the same as the template I pasted above. Is there any reason to believe this old version uploaded to a forum would work better than the official template included with Quartus?
Hi hcom,
Intel training course did mention the template in Timing Analyzer Cookbook as well, linked here.
I believe the JTAG signal constraints template in Cookbook can be used and function well. Just the method is different which used fitter-specific constraints.
Most likely the timing failure is because of the ports {altera_reserved_tdo}. Timing fails there.
I also found something here (page 25) regarding SDC command:
set_max_delay - To relax timing analysis for the setup/ hold checks to not fail.
set_false_path - Identifies specific timing paths as being false. This constraint removes timing requirements on these false paths so that they are not considered during the timing analysis.
I think you can add the second suggestion in top post into text editor template or use this one:
--- Quote Start ---
set jtag_33Mhz_t_period 30
create_clock -name {altera_reserved_tck} -period $jtag_33Mhz_t_period [get_ports {altera_reserved_tck}]
set_clock_groups -asynchronous -group {altera_reserved_tck}
set_max_delay -to [get_ports { altera_reserved_tdo } ] 0
--- Quote End ---
Both methods should work properly as well. The periods 10Mhz or 33Mhz should be both okay depend on which one you choose.
Hope it helps.
Sheng
