Signal Tap example from Intel training course always fails timing
Hi hcom,
Kindly refer to this link.
JTAG signal constraints template in Recent TimeQuest Cookbook (Page 18) probably can help.
Sheng
- hcom4 years ago
@ShengN_Intel That is almost exactly the same as the template I pasted above. Is there any reason to believe this old version uploaded to a forum would work better than the official template included with Quartus?
- ShengN_altera4 years ago
Hi hcom,
Intel training course did mention the template in Timing Analyzer Cookbook as well, linked here.
I believe the JTAG signal constraints template in Cookbook can be used and function well. Just the method is different which used fitter-specific constraints.
Most likely the timing failure is because of the ports {altera_reserved_tdo}. Timing fails there.
I also found something here (page 25) regarding SDC command:
set_max_delay - To relax timing analysis for the setup/ hold checks to not fail.
set_false_path - Identifies specific timing paths as being false. This constraint removes timing requirements on these false paths so that they are not considered during the timing analysis.
I think you can add the second suggestion in top post into text editor template or use this one:
--- Quote Start ---
set jtag_33Mhz_t_period 30
create_clock -name {altera_reserved_tck} -period $jtag_33Mhz_t_period [get_ports {altera_reserved_tck}]
set_clock_groups -asynchronous -group {altera_reserved_tck}
set_max_delay -to [get_ports { altera_reserved_tdo } ] 0
--- Quote End ---
Both methods should work properly as well. The periods 10Mhz or 33Mhz should be both okay depend on which one you choose.
Hope it helps.
Sheng
