11 years agoSignal Tap Error
I'm having problems running signal tap on a board I'm debugging. There are 7 devices on the JTAG chain. After powering up, I launch signal tap and set up the Hardware for USB-Blaster (USB-0). After...
11 years ago --- Quote Start --- Asking an obvious question. Did you use the same JTAG chain to program a bitstream into your FPGA and it worked correctly ? --- Quote End --- No, FPGA bitstream is loaded over active serial link into a configuration flash part
