8 years agoSignal Tap does not support the OpenCore Plus Hardware Evaluation feature
I am trying to build a simple NIOS system in a MAX10 using Quartus 17.0 and Qsys but I keep getting this set of warnings: Warning (12189): OpenCore Simulation-Only Evaluation feature is turned ...
8 years ago --- Quote Start --- Without JTAG, when Nios boots, it will look for code at the reset vector you set in the Nios parameter settings. You're saying your processor isn't connected to anything? You have to have the instruction and data masters connected somewhere. Try using the Lite edition of Quartus instead of Standard unless you have a license for Standard edition. If you don't, have you gone beyond the 30 day trial period for Standard? --- Quote End --- Yes, sorry. I do have an on-chip memory connected, but this is not causing any problems. My Quartus is still within the trial period.
