8 years agoSignal Tap does not support the OpenCore Plus Hardware Evaluation feature
I am trying to build a simple NIOS system in a MAX10 using Quartus 17.0 and Qsys but I keep getting this set of warnings: Warning (12189): OpenCore Simulation-Only Evaluation feature is turned ...
8 years ago --- Quote Start --- I'm not sure why Anand told you to turn off OpenCore Plus; you need it on if you want to be able to use an IP without a license. Let me summarize your setup: Quartus Prime 17.0 (lite or standard edition?) MAX 10 device Nios II /f core Signal Tap Do you have any other IP in your design besides Nios that perhaps requires a license? As the warning says, there's an IP that does not support OpenCore Plus. Nios II /f most definitely does, so perhaps there's something else that doesn't. --- Quote End --- I use Quartus 17.0 standard trial MAX10 Tried all Nios cores including II/e, /f and classic I have not installed Signal Tap separately. I only have Quartus. My test design only has Nios and clock source. Note that when I uncheck "Include JTAG Debug" from the Nios parameters in Qsys, the sof is normally created with no warnings. But with JTAG disabled I cannot program Nios, can I?
