8 years agoSignal Tap does not support the OpenCore Plus Hardware Evaluation feature
I am trying to build a simple NIOS system in a MAX10 using Quartus 17.0 and Qsys but I keep getting this set of warnings: Warning (12189): OpenCore Simulation-Only Evaluation feature is turned ...
8 years agoI'm not sure why Anand told you to turn off OpenCore Plus; you need it on if you want to be able to use an IP without a license.
Let me summarize your setup: Quartus Prime 17.0 (lite or standard edition?) MAX 10 device Nios II /f core Signal Tap Do you have any other IP in your design besides Nios that perhaps requires a license? As the warning says, there's an IP that does not support OpenCore Plus. Nios II /f most definitely does, so perhaps there's something else that doesn't.
