8 years agoSignal Tap does not support the OpenCore Plus Hardware Evaluation feature
I am trying to build a simple NIOS system in a MAX10 using Quartus 17.0 and Qsys but I keep getting this set of warnings: Warning (12189): OpenCore Simulation-Only Evaluation feature is turned ...
8 years ago --- Quote Start --- Hi, Are you using Quartus std edition? Try by changing setting 1. In the Intel Quartus Prime software, click Assignments ➤ Settings ➤Compilation Process Settings. 2. Click the More Settings button. 3. For OpenCore Plus hardware evaluation, select Disable. refer link for more information https://webcache.googleusercontent.com/search?q=cache:6bvcnnmv2q8j:https://www.altera.com/en_us/pdfs/literature/an/an320.pdf+&cd=1&hl=en&ct=clnk&gl=my Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- I have tried that. Still no sof. The warning is now: Warning (12193): OpenCore Plus Hardware Evaluation feature will not be used - it has been explicitly disabled for this design
