8 years agoSignal Tap does not support the OpenCore Plus Hardware Evaluation feature
I am trying to build a simple NIOS system in a MAX10 using Quartus 17.0 and Qsys but I keep getting this set of warnings: Warning (12189): OpenCore Simulation-Only Evaluation feature is turned ...
8 years ago --- Quote Start --- Are you using the fast or economy core? I'm assuming the fast core. And are you using the Lite or Standard edition of Quartus? These are strange warnings. What if you disable Signal Tap? --- Quote End --- I tried all NIOS core versions, including classic. Same result. How do I disable Signal Tap?
