12 years agoI have a 32-bit Windows. I don't have that file in bin64 at all. You definitely shouldn't copy any files between bin and bin64, especially those binary files. 32-bit program can not load 64-bit dlls, and vice versa. It is an operating system thing.
I doubt it is a problem with 13.0. I don't remember I had problem there. I'd say that you should uninstall and re-install. Since you are re-installing anyway, you should just go with sp1. I know I need to enable talkback to use SignalTap. I think I mostly likely enabled it when installer asked. (? or some other step.) It was just 2nd nature to me to answer yes to that question for the sake of using SignalTap. I don't even know this tb2_install.exe program anymore.
