9 years agoSignal not assigned in init state
Hello, I am working on a simple state machine but for some reason the output value is not assigned correctly. First it is supposed to go into state init and assign default values to my 4x8...
9 years agoPuqmaStar,
It just bothered me that I could not see what was wrong so I took a few minutes and ran it myself. Seems to work fine for me. I had to addLIBRARY IEEE; at the top of your code to get it to compile and changed count to 5 instead of 100. Perhaps you just missed that in the cut ans paste. Then did a simple test bench: --
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
use IEEE.NUMERIC_STD.ALL;
use IEEE.MATH_REAL.ALL;
USE std.textio.all;
USE ieee.std_logic_textio.all;
ENTITY TB IS
END TB;
ARCHITECTURE test_arch OF TB IS
constant clock_period : time := 10 ns;
signal clk : std_logic := '0';
signal clock_running : std_logic := '0';
signal sim_done : std_logic := '0';
signal button : std_logic_vector(5 downto 1) := (others => '0');
signal key : std_logic_vector(31 downto 0) := (others => '0');
component buttonToKey
port (
clk_50 : in std_logic;
button : in std_logic_vector(5 downto 1);
key: out std_logic_vector(31 downto 0)
end component;
begin
DUT : buttonToKey
port map (
clk_50 => clk,
button => button,
key => key
Clock process
clock_proc : process
begin
if(clock_running = '1') then
wait for clock_period / 2;
clk <= not clk;
elsif(sim_done = '1') then
wait;
else
wait for 20 ns;
end if;
end process;
Test proc
test_proc : process
begin
-- printf("Test proc\n");
-- printf("clock_period = %e\n", clock_period);
clock_running <= '1';
wait for 20 * clock_period;
for i in 1 to 4 loop
button <= "10000";
for j in 1 to 25 loop
wait for 10 * clock_period;
end loop;
button <= "00001";
wait for 2 * clock_period;
end loop;
clock_running <= '0';
sim_done <= '1';
-- printf("done\n");
wait;
end process;
END test_arch;
and DO file to run it: transcript file ""
transcript file transcript.log
transcript on
if {} {
vdel -lib rtl_work -all
vlib rtl_work
vmap work rtl_work
vcom -2008 -work work {ButtonToKey.vhd}
vcom -2008 -work work {button_test.vht}
vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm -L rtl_work -L work -voptargs="+acc" TB
# add wave *
add wave "/TB/CLK"
add wave "/TB/BUTTON"
add wave -hex "/TB/KEY"
add wave -unsigned "/TB/DUT/count"
add wave -decimal "/TB/DUT/index"
add wave "/TB/DUT/state"
# set sim_time
# puts $sim_time
set t0
run -all
set dt - $t0]
puts $dt
wave zoom full
# set PrefMain(Editor) {C:/Windows/System32/notepad.exe}
# edit transcript
and it works just fine: https://www.alteraforum.com/forum/attachment.php?attachmentid=13409 Note the lines in the DO file that add internal signals to the waveform as Tricky suggested. You must be doing something wrong in the way you run the simulation. In any event, now that I know I'm not crazy (regardless of what others think) my interest in the problem is over. Suffice it to say there are all sorts of issues with your code, but since it sounds like a school project you should figure it out yourself. Good luck.
