9 years agoSignal not assigned in init state
Hello, I am working on a simple state machine but for some reason the output value is not assigned correctly. First it is supposed to go into state init and assign default values to my 4x8...
9 years agoPuqmaStar,
I don't think it explains the strange behavior. It's not a matter of whether or not your way will work so much as efficiency. Your way entails multiple levels of logic. The tools are pretty smart and may be able to optimize it, but I would not depend on that (you could use the Netlist viewers to find out). With a case statement, it can jump to the proper block of hardware. A C/C++ switch statement is similar. The compiler creates a jump table whereas the equivalent if/else code would require evaluating each one until the proper case if found. Also, tools like SignalTap have special ways of handling FSM if it recognizes it. You can tell it to insert the FSM and it will use the named states. If your purpose in the count was to help meet timing, I would just get rid of it. Your simulation will be alot faster. For RTL simulation, timing does not matter and it actually hurts timing in any event. You've added more levels of logic. It looks to me like you properly initialize the state variable and count. Resets are not a bad thing, but it seems like it should have worked before. Not sure why your code caught my interest. Seems like it should work and probably something obvious.
