9 years agoSignal not assigned in init state
Hello, I am working on a simple state machine but for some reason the output value is not assigned correctly. First it is supposed to go into state init and assign default values to my 4x8...
9 years agoOne way it works if a synchronous reset is implemented. If that is done the state machine starts in init as it should have done. This was not my doing btw. Credit goes to my TA who found that out.
Below the working code: if rising_edge( clk_50 ) then
if rst = '0' then
state <= init;
else
if state = init AND count = 100 then -- init and assign default char
state <= assign;
key_int( 3 ) <= x"61"; -- ASCII 'a'
key_int( 2 ) <= x"61";
key_int( 1 ) <= x"61";
key_int( 0 ) <= x"61";
count <= ( others => '0' );
-- key <= "11111111111111111111111111111111"; -- debug
elsif state = evaluate then -- check which button is pressed
if button = "10000" then -- button 5: increment ASCII character
state <= assign;
if unsigned( key_int( index ) ) = x"7A" then -- run circular between ASCII char 'a' and 'z'
key_int( index ) <= x"61";
else
key_int( index ) <= key_int( index ) + 1;
end if;
elsif button = "00001" then -- button 1: move to next position (start with 1)
state <= evaluate;
if index = 3 then
index <= 0; -- overflow protection
else
index <= index + 1;
end if;
else
state <= evaluate;
end if;
elsif state = assign AND count = 100 then -- assign any changed keys to output
state <= evaluate;
-- key <= key_int4 & key_int3 & key_int2 & key_int1;
key <= key_int( 3 ) & key_int( 2 ) & key_int( 1 ) & key_int( 0 );
-- key <= "00000000001111111111000000000011"; -- debug
else
count <= count + 1;
end if;
end if; --- Quote Start --- It's not related to your question and just my two cents, but this is not a usual way to structure a FSM. Most people would use a case statement for each state. I'm not sure the tools will even recognize your code as a FSM (should still work though). --- Quote End --- Yes you are right. This is not the standard state machine and if I look at the state machine template from the altera website - link (http://quartushelp.altera.com/15.0/mergedprojects/hdl/vhdl/vhdl_pro_state_machines.htm) or here - link (https://www.altera.com/support/support-resources/design-examples/design-software/vhdl/vhd-state-machine.html) it uses case state ..when=> structure but it does not say it is a nessecity. In the quartus ii handbook volume 1 - link (https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0ahukewjelyg5yu_sahujpiykhc1xd40qfggamaa&url=https%3a%2f%2fwww.altera.com%2fen_us%2fpdfs%2fliterature%2fhb%2fqts%2fqts-qps-5v1.pdf&usg=afqjcngnr1gq2_khvwqn9afvdjhqkzw35g&sig2=k1pkspsuefhkqwmvfcrmxq&bvm=bv.150729734,d.ewe) on page 12-50 it only says that to be recognized as a state machine I must use state type like this TYPE Tstate IS (state_0, state_1, state_2, state_3, state_4);
SIGNAL state: Tstate; and also gives a few more suggestions. Maybe that explains the strange behaviour? Maybe the case state ..when=> structure or a reset are necessary? Well, I don't know for sure now but since I got it working with above code I am satisfied for now! Thanks @tricky and @corestar for your help and suggestions!
