9 years agoSignal not assigned in init state
Hello, I am working on a simple state machine but for some reason the output value is not assigned correctly. First it is supposed to go into state init and assign default values to my 4x8...
9 years agoIt does look like you should see "key" change. It's not related to your question and just my two cents, but this is not a usual way to structure a FSM. Most people would use a case statement for each state. I'm not sure the tools will even recognize your code as a FSM (should still work though).
It's not clear what you mean by "I already placed a counter in both states so I don't get a timing problem." but the code would be much more clear if you put the counter in a separate process so that it is incremented and reset in one place instead of several.
counter_expired <= '1' when counter = 100 else '0';
counter_proc : process
begin
wait until CLK'EVENT and CLK = '1';
if(counter = 100 or reset_counter = '1') then
counter <= (others => '0');
else
counter <= counter + 1;
end if;
end process counter_proc;
then in the FSM:
case state is
when init =>
if(counter_expired = '1') then
end if;
If you are using VHDL 2008, you can access internal signal names in a testbench using the VHDL 2008 external names. Some examples here: http://stackoverflow.com/questions/17287129/vhdl-alias-syntax (http://stackoverflow.com/questions/17287129/vhdl-alias-syntax) In fact, a simulation is sort of useless if you do not do so. Being VHDL, it is ten times more verbose than necessary, but it works. Sorry for the unsought for suggestions; clearly had too much time on my hands today.
