13 years agoSignal names in Quartus / Timequest
I am working on a Cyloone IV design which uses the altlvds megafunction.
The output clcok of this megafunction is called rx_outclock. In my verilog code it is assigned to a signal called lvds_a_clk_rx_par. Here is the call to the altlvds function: altlvds_rx_28bits altlvds_rx_28bits_serdes ( // need to check lpm parameters: input data rate, channels 5, etc? .rx_in ( lvds_a_rx_ser[3:0] ), .rx_inclock ( lvds_a_clk_rx_ser ), .rx_out ( { rx_pair3_28bits[6:0], rx_pair2_28bits[6:0], rx_pair1_28bits[6:0], rx_pair0_28bits[6:0] } ), .rx_outclock ( lvds_a_clk_rx_par ) ); This clock (lvds_a_clk_rx_par) is used later in the verilog code to clock registers. When I go into Timequest to check timing and set up constraints I cannot find this clock. The clock that does show up instead is this: altlvds_rx_28bits_serdes|ALTLVDS_RX_component|auto_generated|lvds_rx_pll|clk[2] I can set constraints to this clock and it seems to work ok. I tried to rename this clock to lvds_a_clk_rx_par in the sdc file with the -name option in the create generated clock statement, but that did not work. Is there a way for Quartus and Timequest to use the signal names in my Verilog design file instead of the altlvds auto generated names?
