16 years agoThe full name is needed internally to identify the signal unequivocally, I think. You may want to use shorter instance and component names to avoid "ridiculously" long identifiers. But you can set a short alias name. You can modify the stp file on a local computer with SignalTap or edit the *.stp XML file directly.
