17 years ago
shift register coding problem
I wonder if someboy could take a look on my code on 5x9 shift register. It seems to me that input d is connected to the design. I am using multidimensional array.
I am new to VHDL :confused:
library ieee ;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ShiftReg is
port( d: IN STD_LOGIC_VECTOR(4 downto 0);
Q: OUT STD_LOGIC_VECTOR(4 downto 0);
Clk: IN STD_LOGIC
end ShiftReg;
architecture archi of ShiftReg is
type register5x9 is array (0 to 4) of STD_LOGIC_VECTOR (8 downto 0);
signal tmp: register5x9;
begin
process (Clk)
begin
if Clk'event and Clk='1' then
tmp(0)(8) <= d(0);
tmp(1)(8) <= d(1);
tmp(2)(8) <= d(2);
tmp(3)(8) <= d(3);
tmp(4)(8) <= d(4);
for i in 8 downto 1 loop
for j in 4 downto 1 loop
tmp(j-1)(i-1) <= tmp(j)(i);
end loop;
end loop;
end if;
Q(0) <= tmp(0)(0);
Q(1) <= tmp(1)(0);
Q(2) <= tmp(2)(0);
Q(3) <= tmp(3)(0);
Q(4) <= tmp(4)(0);
end process;
end archi;
    To infer a shift register, your signal is ok, just do this in the clocked process:
    tmp(0) <= d;
    for i in 1 to 4 loop
    tmp(i) <= tmp(i-1);
    end loop;
    -- outside process:
    Q <= tmp(4);
    you also need to correct the data width to 5 bits. reverse the array orientation
    type register5x9 is array (0 to 8) of STD_LOGIC_VECTOR (4 downto 0);
    for i in 1 to 8 ..etc
    Because of the strange two-dimensional shift operation, input d is ignored and all-zero shifted to the output.
    Actually I don't see a clear intention with the code.
    It was just an experiment for me. I am trying to learn more about Digital design.
    Karl Hi
    In Quartus, when Your VHDL file opened in text editor, select:
    Edit -> Insert Template -> VHDL -> Full Designs ...
    For single bit shift, one can also use this compact statement:
    --assuming input is d (one bit) output is Q(one bit), tmp is 16 bit:
    --in a clocked process
    tmp<= tmp(14 downto 0) & d;
    Q <= tmp(15);
