9 years agoShift constant by variable amount
For some reason, I can't get this to work. I want to logically shift left the 8-bit number 1 (x"01") by a variable amount (named counter between 0 and 7) and store as an inverted std_logic_vector. ...
9 years agoWell, I still kept getting errors about **, so I put in the counter-sensitive process solution, inverting the values since I need it active low for LEDs. It seems to work! Thanks for the help!
