Sharing of signals over different processes in modelsim not working as expected ?
- 8 years ago
- That is because enable_clock is set to '1' after the first falling edge of the clock, and it remains at '1'.
The thrid process (main_data_gen) is waiting for enable_clock to toggle to '1' after the second clock. But it already at '1', and hence waits forever.
Wait until is triggered by a 'event on the sensitivy list (the signals you are waiting for).
the workaround is to do this:
if enable_clock /= '1' then wait until enable_clock = '1'; end if;2. Now to comment on the code. Why are you manually waiting for edges on the clock? VHDL has the build in functions rising/falling_edge, so its usually much better to use those on the code, and is more readable. in addition, use loops to wait for a defined number of clocks:
for i in 1 to 10 loop -- wait for 10 clocks wait until rising_edge(clk); end loop;or even better, in some tools package, define a procedure to wait for a specified number of clocks (its a pretty standard thing to want to do in any testbench:
procedure wait_for_clks( constant n : integer; signal clk : in std_logic ) is begin for i in 1 to n loop wait until rising_edge(clk); end loop; end procedure; ....... process begin ...... wait_for_clks(10, clk); end process;3. Next, if you want a process to halt, putting wait until 0=1; will wait forever, but its a fairly nonsense piece of code. Why not simply write "wait", as a single wait will wait forever
stim_proc : process begin ....do something wait_for_clks(10, clk); .. do something else wait; -- waits forever; end process;4. For the PSD_data_table, why not set the values in an initialisation function, rather than assign them in a process?
Hello Tricky,
High appreciation for you analysis: Following Your comments:
1. AFIK, Vhdl does not support "wait until" statements & parameters in the process sensitivity list, so solving the issue using an explicit process sensitivity list is was a dead end.
Your workaround for this property is very nice. I tried it; it works, this solution I would not have found myself. An alternative solution elaborating on and confirming your analysis: wait until (enable_clock and CLOCK_50) = '1' this also seems to work; "wait until" is evaluated each time "clock_50" changes.
2. Your solution is better. I have a C++ background, my old habbit is not completely dead yet for code that does not end up in an FPGA. I modified my code in line with your remarks. I also see speed improvements during simulation.
3. "Wait" was something I have been looking for but did not come across yet. Thanks.
4. The values in the .mif are generated by an .xls script. They will also be used in a second FPGA (DE2-115) I use it as a wave generator for the main FPGA (DE10-STD). I generate a complex wave form that will finally come out of a rotating wheel in front of a PbS sensor. I could generate a .vhd the same way I generate the .Mif file of course but if you try nothing you learn nothing.
Johi.
