Sharing of signals over different processes in modelsim not working as expected ?
- 8 years ago
- That is because enable_clock is set to '1' after the first falling edge of the clock, and it remains at '1'.
The thrid process (main_data_gen) is waiting for enable_clock to toggle to '1' after the second clock. But it already at '1', and hence waits forever.
Wait until is triggered by a 'event on the sensitivy list (the signals you are waiting for).
the workaround is to do this:
if enable_clock /= '1' then wait until enable_clock = '1'; end if;2. Now to comment on the code. Why are you manually waiting for edges on the clock? VHDL has the build in functions rising/falling_edge, so its usually much better to use those on the code, and is more readable. in addition, use loops to wait for a defined number of clocks:
for i in 1 to 10 loop -- wait for 10 clocks wait until rising_edge(clk); end loop;or even better, in some tools package, define a procedure to wait for a specified number of clocks (its a pretty standard thing to want to do in any testbench:
procedure wait_for_clks( constant n : integer; signal clk : in std_logic ) is begin for i in 1 to n loop wait until rising_edge(clk); end loop; end procedure; ....... process begin ...... wait_for_clks(10, clk); end process;3. Next, if you want a process to halt, putting wait until 0=1; will wait forever, but its a fairly nonsense piece of code. Why not simply write "wait", as a single wait will wait forever
stim_proc : process begin ....do something wait_for_clks(10, clk); .. do something else wait; -- waits forever; end process;4. For the PSD_data_table, why not set the values in an initialisation function, rather than assign them in a process?
begin
end loop;
end procedure;
process
begin
stim_proc : process
begin
....do something
