12 years ago
share data pins with address pins of SDRAM in QSYS?
In my design, i must share the data pins of SDRAM with address pin of the same SDRAM,
so how could do that.
Use the sdram controller (share pins via tri-state bridge)?
or use the Generic Tristate Controller?
thank you very much!!
    As far as I know the generic tristate controller can't share the data and address on the same pins. You will need to use a SDRAM controller, or make your own.
    thank you for you reply!
    In QSYS, i select the SDRAM controller and avalon-MM tristate bridge, then in the SDRAM controller I select the tristate bridge as share pins via tristate bridge.
    but how could i connect the "avalon memory mapped tristate master" port of avalon-MM tristate bridge module?
