evyatar
4 years agosetup timing from fifo
a strange setup timing violation: the path is from the 'write enable' of a FIFO, to another register in the design. it seems like a problem in the Quartus 2 (64 bit V14.1.0 B186 12/3/14 SJ Full Ver...
KennyT_altera
4 years agoFor fifo, there are some constrain mention in the user guide: https://www.intel.com/programmable/technical-pdfs/683522.pdf, You may take a look if it suite your case
When you set a false path, this means that you do not care whether that path meet any timing wrt to clock. My suggestion is to send us your whole design.qar to take a look first. My suggestion is to use set_multicycle path is the path is too long, or add register in btw the path.
