Setup failed for altera_reserved_tdo
- 3 years ago
Hello Chris,
In the jtag constraint look for
proc set_tck_timing_spec { } {
# USB Blaster 1 uses 6 MHz clock = 166.666 ns period
set ub1_t_period 166.666
# USB Blaster 2 uses 24 MHz clock = 41.666 ns period
set ub2_default_t_period 41.666
# USB Blaster 2 running at 16 MHz clock safe mode = 62.5 ns period
set ub2_safe_t_period 62.5
In snipper above,you may comment 16MHz and 24Mhz, and
set tck_t_period $ub2_default_t_period
change the $ub2_default_t_period --> ub1_t_period
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
