9 years agoSetup default project location
Hello, When I create a new project, the following location appears in the dialog window "C:\altera\15.1". How to change it for a new location ? Thanks.
wizardberry
3 years agoLooks like if you update the shortcut that you use (start menu or desktop) to get into quartus, the default location for projects is based on the "Start in" windows shortcut field. I updated this to reflect %userprofile%\desktop and clicked ok and now it creates projects with that folder as the root. I don't believe you can choose a folder that doesn't exist, but putting it at the root of desktop or documents at least gets it to a user-specific folder that makes sense for your users to specify a subfolder for projects to start from.
