17 years ago --- Quote Start --- That clock network delay probably isn't what you think it is. Use "-detail full_path" instead of "-detail path_only" for report_timing to see what is in the clock path. --- Quote End --- Thanks. This is the result (new signal top violation since the previous went away via HDL recoding): Info: Path# 1: Setup slack is -0.905 (VIOLATED) Info: =================================================================== Info: From Node : NXT Info: To Node : MessageEncoder:inst2|MessageEncoderFifo:inst2|scfifo:scfifo_component|scfifo_0e31:auto_generated|a_dpfifo_f531:dpfifo|dpram_m011:FIFOram|altsyncram_s1k1:altsyncram2|altsyncram_qrc1:altsyncram3|ram_block4a5~portb_we_reg Info: Launch Clock : CLK_OUT_60 Info: Latch Clock : pll_clk_60 Info: Info: Data Arrival Path: Info: Info: Total (ns) Incr (ns) Type Element Info: ========== ========= == ==== =================================== Info: 0.000 0.000 launch edge time Info: 0.000 0.000 source latency Info: 0.000 0.000 CLK_IN_48 Info: 1.066 1.066 RR CELL CLK_IN_48|combout Info: 3.525 2.459 RR IC inst|altpll_component|pll|inclk[0] Info: -2.031 -5.556 RR COMP inst|altpll_component|pll|clk[1] Info: -1.260 0.771 RR IC inst|altpll_component|_clk1~clkctrl|inclk[0] Info: -1.260 0.000 RR CELL inst|altpll_component|_clk1~clkctrl|outclk Info: -0.072 1.188 RR IC CLK_OUT_60|datain Info: 2.939 3.011 RR CELL CLK_OUT_60 Info: 10.239 7.300 R iExt NXT Info: 11.173 0.934 RR CELL NXT|combout Info: 12.770 1.597 RR IC inst1|msg_data_type~435|datac Info: 13.092 0.322 RR CELL inst1|msg_data_type~435|combout Info: 13.393 0.301 RR IC inst5|out_msg_data_valid~78|datac Info: 13.671 0.278 RR CELL inst5|out_msg_data_valid~78|combout Info: 14.161 0.490 RR IC inst2|inst2|scfifo_component|auto_generated|dpfifo|fifo_state|valid_wreq~_Duplicate_RESYN1008|datad Info: 14.339 0.178 RR CELL inst2|inst2|scfifo_component|auto_generated|dpfifo|fifo_state|valid_wreq~_Duplicate_RESYN1008|combout Info: 14.810 0.471 RR IC inst2|inst2|scfifo_component|auto_generated|dpfifo|fifo_state|valid_wreq~_Duplicate|datac Info: 15.132 0.322 RR CELL inst2|inst2|scfifo_component|auto_generated|dpfifo|fifo_state|valid_wreq~_Duplicate|combout Info: 17.030 1.898 RR IC inst2|inst2|scfifo_component|auto_generated|dpfifo|FIFOram|altsyncram2|altsyncram3|ram_block4a5|ena1 Info: 17.772 0.742 RR CELL MessageEncoder:inst2|MessageEncoderFifo:inst2|scfifo:scfifo_component|scfifo_0e31:auto_generated|a_dpfifo_f531:dpfifo|dpram_m011:FIFOram|altsyncram_s1k1:altsyncram2|altsyncram_qrc1:altsyncram3|ram_block4a5~portb_we_reg Info: Info: Data Required Path: Info: Info: Total (ns) Incr (ns) Type Element Info: ========== ========= == ==== =================================== Info: 16.666 16.666 latch edge time Info: 16.666 0.000 source latency Info: 16.666 0.000 CLK_IN_48 Info: 17.732 1.066 RR CELL CLK_IN_48|combout Info: 20.191 2.459 RR IC inst|altpll_component|pll|inclk[0] Info: 14.635 -5.556 RR COMP inst|altpll_component|pll|clk[1] Info: 15.406 0.771 RR IC inst|altpll_component|_clk1~clkctrl|inclk[0] Info: 15.406 0.000 RR CELL inst|altpll_component|_clk1~clkctrl|outclk Info: 16.124 0.718 RR IC inst2|inst2|scfifo_component|auto_generated|dpfifo|FIFOram|altsyncram2|altsyncram3|ram_block4a5|clk1 Info: 16.907 0.783 RR CELL MessageEncoder:inst2|MessageEncoderFifo:inst2|scfifo:scfifo_component|scfifo_0e31:auto_generated|a_dpfifo_f531:dpfifo|dpram_m011:FIFOram|altsyncram_s1k1:altsyncram2|altsyncram_qrc1:altsyncram3|ram_block4a5~portb_we_reg Info: 16.867 -0.040 uTsu MessageEncoder:inst2|MessageEncoderFifo:inst2|scfifo:scfifo_component|scfifo_0e31:auto_generated|a_dpfifo_f531:dpfifo|dpram_m011:FIFOram|altsyncram_s1k1:altsyncram2|altsyncram_qrc1:altsyncram3|ram_block4a5~portb_we_reg Info: Info: Data Arrival Time : 17.772 Info: Data Required Time : 16.867 Info: Slack : -0.905 (VIOLATED) Info: =================================================================== Info: So, I see that the clock *really* goes from the CLK_48_MHZ input pin, through the PLL, out onto the internal global clock network and finally goes out on the CLK_OUT_60 pin to the external FIFO. What i don't understand is why the zero time is not counted from the external CLK_OUT_60 pin which is what i intended to use as clock in the SDC. I must get something conceptually wrong since i would assume t=0 should be the CLK_OUT_60 element. In fact, if i specify the 60 MHz PLL clock as reference the timing violation goes away - i'm however not sure this approach is correct (neighter of the clock options appear correct, really). As can be seen in the path above, the major delays are really the 'clock network delay' and the 7.3ns delay to compensate for the external device's Tco. If i can get rid of the 'clock delay' i would meet timing...
