19 years agoSetting the I/O bank voltage
I'm hoping some kind soul can help me out here. I'm trying to build the reference design (originally built with Q-II 7.1) that came with my LPRP board. One of the problems is that Quartus II 7....
rjadh1
7 years agoThe issue happened on the grounds that the outside arrangement gadget associated on those banks was defaulting to a 2.5V I/O standard in Quarts II. Quarts II 7.2 currently has a choice to characterise the Arrangement bank pins I/O voltage explicitly.
The Means are
1. Open the venture in Quartus II 7.2
2. Select Assignments - > Gadget "pull down menu"
3. Press the Gadget and Stick Choices "Catch"
4. Select the Setup "tab"
5. Select 1.8V in the Setup gadget I/O voltage "pull down window"
6. Select alright in the two windows to exit
7. Recompile the structure.
