19 years agoSetting the I/O bank voltage
I'm hoping some kind soul can help me out here. I'm trying to build the reference design (originally built with Q-II 7.1) that came with my LPRP board. One of the problems is that Quartus II 7....
19 years agoI have listed the steps below to resolve this issue.
The problem occurred because the external configuration device connected on those banks was defaulting to a 2.5V I/O standard in Quartus II. Quartus II 7.2 now has an option to define the Configuration bank pins I/O voltage specifically. The Steps are 1. Open the project in Quartus II 7.2 2. Select Assignments ---> Device "pull down menu" 3. Press the Device & Pin Options "Button" 4. Select the Configuration "tab" 5. Select 1.8V in the Configuration device I/O voltage "pull down window" 6. Select OK in both windows to exit 7. Recompile the design
