16 years ago
Setting output value in waveform file...
I have a waveform file with some input and outputs....
When I simulate, I get what it's expected... So, there's no problem.
But, I would to set some output (at the begining of the waveform) to simulate a previous state... in the waveform I can set the outputs from XXXX state to a defined state... But, of course, when I launch the simulation, the outputs don't stay a these values ?
I tried to change the output pins to bidir pins, (in the .bdf and the .wvf) but there was no effect...
How can I do ?
    If you are using VHDL, just for simulation, try this:
    signal rx: std_logic_vector(7 downto 0):= "xxxxxxxx"; --Any value
    your_output<=rx;
    rx should be a register output.
    Thank you for your reply !
    But I'an using a Vector Waveform File...
    Do you know if it's possible in this case ?
    Thank you.
    I think quartus doesn't allow it, it wouldn't be consistent with the behavior of the hardware.
    I'm not sure, if I'm yet aware of all Quartus simulator features. But I think, it doesn't allow easy forcing of signals during simulation run. This is a privilege of full-featured simulators as ModelSim. But there are most likely means to achieve the intended behaviour anyway. To manipulate an output signal at a given simulation time, you can add a tristate function to the driver and control it by an additional signal.
    The software handbook also mentions the option to edit internal memory contents at simulation breakpoints.
