13 years agoHi Martin,
--- Quote Start --- Thanks a lot for the examples! Are these TCL scripts handwritten or are you using some shortcuts to create these files? --- Quote End --- They're handwritten. However, the versions I use are less verbose. Tcl allows you to put scripts in a common location that is specified by the TCLLIBPATH path environment variable. You can put the re-useable Tcl procedures in scripts there. I use environment variables to describe where I want everything. Since I don't want to have to make people setup their environment before they can use my scripts, I dumbed them down first :) I also have Quartus and Modelsim output their build results into a version specific folder, eg., in the c:/build directory, I have c:/build/quartus/v9.0_sp2_full c:/build/quartus/v10.1_full c:/build/quartus/v11.1_sp2_full c:/build/modelsim/v6.5b_se c:/build/modelsim/v6.6c_ase c:/build/modelsim/v6.6d_ase c:/build/modelsim/v10.0c_ase i.e., I have Quartus and its corresponding Modelsim-ASE, and I have a full-edition of Modelsim-SE. This allows me to build the same project with multiple versions of Quartus+Modelsim while keeping the build results. I use CVS for source control. Cheers, Dave
