Setting 100ohm input on-chip differential termination in Pin planner or Assignment Editor in Quatus?
- 5 years ago
Assignment editor is the tool for assigning various pins. Pin Planner is special tool for pin assignments that include a panorama of pins and it is really helpful for more advanced designs since it you can see where are you assigning the pins.
Thank you.
up
You can set the assignment in either the Pin Planner or the Assignment Editor or write directly in the .qsf. They all do the same thing.
- xytech5 years ago
Contributor
since we can do the assignment in either Pin Planner or the Assignment Editor, why do these two tools exist at the same time? What is their difference? Thanks.
- AminT_Intel5 years ago
Thank you.
- sstrell5 years ago
The Assignment Editor lets you create assignments for everything in a design, including I/O. The Pin Planner is exclusively for I/O, making it easier to create I/O assignments through a graphical interface.
