12 years ago
Set up flash in Qsys
I want to boot my software from a flash memory but first i need to set up the hardware. Can anyone help me to set up the hardware? I'm using Qsys but all the "how to" i find are all uing System Builder. And when I have my hardware do I need too include a bootloader in my software or does the tools do i for me?
Thank you for your help :)
    It depends of how do you set up your board. An usual scheme is :
    - FPGA Hardware config in an EPCS memory through Active Serial connection with the generated .pof file to this OR program FPGA through JTAG with the generated .sof file. <-- "Quartus Programmer"
    - Embedded software in FLASH memory through JTAG with a running FPGA with your Qsys and co. The NIOS II IDE/SBT does compile and generate the .elf file. If you want to program the FLASH with bootloader + your software : Nios II IDE.SBT > Nios > Nios II Flash Programmer does the job.
    If you are at ease in command line, you can find quite easily the commands used by Nios II SBT : see .sh in your BSP directory.
    You may experienced "No Qsys connection" when you use Nios II Flash Programmer or with "Run as/ Debug as" with "Quartus programmer" opened.
    I advise to CLOSE Quartus Programmer after using it and before launch Nios II SBT.
    Ok I have understand that, but when i crate my hardware in Qsys I need to add an flash component, right? And if I want my software to be stored in a SDRAM on boot up i have reed something about that I need a tristate-brige to connect the flash and the SDRAM. It is that setup i do not understand.
    The default bootloader copies your software from flash to RAM. It is transparant, d'ont worry about that.
    Do you need to add a flash component in QSYS ? Yes of course.
    Do you need tri-state ... in Qsys ? It depends of your board. If physically Your address and data bus are shared between RAM and FLASH then yes.
    It a bit more difficult and complex to add tristate components in Qsys. Follow Altera User Guide (.pdf) From Altera Litterature web site.
