9 years agoSet undriven outputs to VCC / GND
Hello, Does exist some option that allows to set all unused outputs to VCC/GND ? Thanks.
9 years ago --- Quote Start --- There used to be, and you should NEVER EVER use this option. Why? Consider the case where you have a board with lots of I/Os connected to external devices, eg., a processor. Now lets say you create a "blinky LED" design that uses the clock and LEDs, and you set all other I/Os as driven to VCC or GND. Q: What do you think happens to your board when you configure the FPGA? A: It powers up ever so briefly before the driver conflicts on the FPGA and the external devices cause the FPGA to get so hot that it is destroyed. Yep, I learnt this one the hard way. The precursor to Quartus (MAX+Plus II) had the default to drive unused I/Os to ground. I repeat NEVER EVER define unused I/Os as GND/VCC! Cheers, Dave --- Quote End --- Ok, thanks Dave. So, the only option to avoid a weak glow of LEDs on my DE1 terrasic card is to set to '0' the corresponding ports programmatically (e.g. in "Initial" section or with "assign") ?
